Введение
This guide will help you locate and replace your hard drive on your computer.
Выберете то, что вам нужно
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a Phillips 1 Screwdriver to remove the four 2.4 mm screws securing the hard drive.
Use the black pull-tab located on the shell covering the hard drive, to lift the hard drive housing and pull the hard drive away from the connector.
2 участников успешно повторили данное руководство.
