Введение
This guide will show the user how to safely remove and replace the keyboard.
Выберете то, что вам нужно
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a nylon spudger to carefully pry the top back panel off.
Disconnect the four-pin connector and remove the top back panel from the computer.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Lift away the metal housings from each side of the laptop.
Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
Use a pair of tweezers to undo each of the four ribbon connectors.
The keyboard is now completely disconnected from the laptop and you can remove it.
2 участников успешно повторили данное руководство.
Один комментарий
Only shows you how to remove keyboard panel from chasis, not how to actually remove the keyborad from the keyboard panel to replace. sad.
