Введение
This guide demonstrates the step-by-step removal of the Asus ROG G751JL-DS71 screen. Before proceeding, unplug your device from its power source.
Запчасти
Никакие детали не требуются.
  1. Lift the rubber cover found on the bottom of the laptop. Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Use the nylon spudger to remove the back center panel. Use the nylon spudger to remove the back center panel. Use the nylon spudger to remove the back center panel.
    • Use the nylon spudger to remove the back center panel.
  3. Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel. Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Pull out the optical drive found on the side of the laptop. Pull out the optical drive found on the side of the laptop.
    • Pull out the optical drive found on the side of the laptop.
  5. Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop. Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  6. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  7. Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws. Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Use a nylon spudger to carefully pry the top back panel off. While removing the top back panel, be careful not to break the four pin connector located underneath. Disconnect the four-pin connector and remove the top back panel from the computer.
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel. Lift away the metal housings from each side of the laptop. Lift away the metal housings from each side of the laptop.
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    • Lift away the metal housings from each side of the laptop.
  10. Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place. Use a Phillips 1 Screwdriver to remove  the four 5.2 mm screws underneath the center panel.
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
  11. Use a plastic opening tool to pry the keyboard from the base of the laptop. Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard. Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
    • Use a plastic opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Use a pair of tweezers to undo each of the four ribbon connectors. The keyboard is now completely disconnected from the laptop and you can remove it.
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Use a pair of tweezers to carefully disconnect the pin connector. Use a pair of tweezers to carefully disconnect the pin connector.
    • Use a pair of tweezers to carefully disconnect the pin connector.
  14. Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel. The monitor is now free to be completely lifted off the laptop. The monitor is now free to be completely lifted off the laptop.
    • Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel.
    • The monitor is now free to be completely lifted off the laptop.
Заключение
Alex C Gonzalez
Участник с: 22.01.2018
106 Репутация
1 Guide authored
Команда
Cal Poly, Team S16-G1, Banghart Winter 2018 Member of Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 4
За всё время: 144
