Введение
Use this guide to replace the hard drive in your device.
Выберете то, что вам нужно
Lift up the rubber tab located in the upper-right corner of the backing plate.
Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
Use a Phillips head screwdriver to remove the four 2.4 mm screws from the hard drive mount.
Remove the hard drive from the device.
Почти готово!
Заключение
