Asus ROG Strix GL702VM-BHI7N09 Fan Replacement
Выберете то, что вам нужно
  1. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Back Panel: шаг 1, изображение 1 из 2 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Back Panel: шаг 1, изображение 2 из 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 2, изображение 1 из 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 2, изображение 2 из 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 2, изображение 3 из 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Fan: шаг 3, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
  4. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 4, изображение 1 из 1
    • The smaller black fan must be removed before the larger gray fan on the right can be taken out.
    • To remove the black fan, pull gently on the connecting cables outlined.
  5. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 5, изображение 1 из 1
    • Unplug the white connector by gently pulling the cables.
    • Lift off the gray fan.
  6. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 6, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the two indicated 4 mm screws from the other gray fan.
  7. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 7, изображение 1 из 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 7, изображение 2 из 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: шаг 7, изображение 3 из 3
    • Unplug the white connector by gently pulling it towards the center of the computer.
    • Lift the fan out of the body of the laptop to remove it.
Заключение
9 участников успешно повторили данное руководство.
Zach Langer
Участник с: 04/10/17
676 Репутация
Автор 4 руководств
Команда
Cal Poly, Team S13-G2, Forte Spring 2017 Участник Cal Poly, Team S13-G2, Forte Spring 2017
CPSU-FORTE-S17S13G2
4 членов
Автор 4 руководств
8 Комментариев
one of my laptop fans doesn’t work. where can i get a new one? I didn’t see any new fans for this model of laptop for sale anywhere
Mohammadreza Safaee - Ответить
محمد رضا جان شما میتونید فن رو باز کنید و مشابهش رو از بازار تهیه کنید
Alireza Soheili -
I was wondering the same. I couldn’t find fans anywhere and after contacting ASUS about them they seemed less than interested in selling me the fans so that I could fix my laptop myself.
Chris Moody - Ответить
Can’t seem to find the fan anywhere
jon_souza - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 18
За всё время: 9,012
