Asus S500 USB, Headphone, and SD card Port board replacement
Выберете то, что вам нужно
  1. Asus S500 USB, Headphone, and SD card Port board replacement, USB, Headphone, and SD card Ports: шаг 1, изображение 1 из 1
    • Unscrew the 10 screws on the back cover
  2. Asus S500 USB, Headphone, and SD card Port board replacement: шаг 2, изображение 1 из 1
    • Remove back cover (pry open along the grey/black line, they are held together by clips)
  3. Asus S500 USB, Headphone, and SD card Port board replacement: шаг 3, изображение 1 из 1
    • Lift up tab and pull out the connector
    • Unscrew the 4 screws
    • Open up the screen (as you would to open up the laptop), and in doing so the metal piece will open up.
    • Jostle the ports and remove the small board.
Заключение
5 участников успешно повторили данное руководство.
Isaac Lemus
Участник с: 04/29/14
232 Репутация
1 руководство автора
2 Комментариев
where can i buy the usb mic part?
jorg123 - Ответить
I have a [newish] 14” Asus 3 [Blue Al./gold trim]. One of my grandchildren has wrecked one of the usb 3.1 sockets on the right [Output] side.
Is it possible to renew this socket? I have all the tools + mini soldering iron. I could connect the remaining one to a usb hub I suppose but it’s an expensive machine and I would rather it be repaired.
Any help/advice very much appreciated. Regards - Denis
Denis TRAYNOR - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 3,617
