Введение
Access and remove the left side USB Ports/Headphone Jack/ SD Card Slot.
Выберете то, что вам нужно
Remove back cover (pry open along the grey/black line, they are held together by clips)
Lift up tab and pull out the connector
Unscrew the 4 screws
Open up the screen (as you would to open up the laptop), and in doing so the metal piece will open up.
Jostle the ports and remove the small board.
5 участников успешно повторили данное руководство.
2 Комментариев
I have a [newish] 14” Asus 3 [Blue Al./gold trim]. One of my grandchildren has wrecked one of the usb 3.1 sockets on the right [Output] side.
Is it possible to renew this socket? I have all the tools + mini soldering iron. I could connect the remaining one to a usb hub I suppose but it’s an expensive machine and I would rather it be repaired.
Any help/advice very much appreciated. Regards - Denis
