Введение
If your device does not produce any sound, follow this guide to replace the faulty speaker.
Выберете то, что вам нужно
Disconnect the dock and make sure the power is turned off.
Use plastic opening tool to pry screen up and remove from outer casing.
Pull up on the black circuit board protector.
Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
Use the same screwdriver to remove two 3mm screws connecting the clips.
Use tweezers to remove two wires connected from the battery to the motherboard.
Use the spudger to remove he battery from the case.
Use the tweezers to remove the speaker unit from its clip by pulling on the white plug.
Use a Phillips #00 Screwdriver to remove all of the 3mm screws that is connected with the speaker.
Use plastic opening tool to take out the speaker.
Еще один человек закончил это руководство.
