Введение
The back cover of the Asus TUF Gaming FX705G must be removed before any internal repairs and replacements. This is the first step for nearly all laptop replacement guides. Find a good spot in the seam around the bottom half of the laptop in order to avoid breaks or cracks. Before removing the back cover, you may also want to check for any cracks or missing screws.
Запчасти
Детали не указаны.
  1. Remove the eleven Phillips #0 screws that secure the back cover. Remove the eleven Phillips #0 screws that secure the back cover.
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward. You will hear pops as the back cover releases.
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
    Hey so the screws are two different lengths. This would be more helpful if you could point out which screws go in which sockets!
    paul - Ответить
Заключение
Еще один человек закончил это руководство.
Tyler Lange
Участник с: 15.10.2019
345 Репутация
Автор 2 руководств
Команда
Grand Valley State University, Team S4-G5, DeVasto Fall 2019 Участник Grand Valley State University, Team S4-G5, DeVasto Fall 2019
GVSU-DEVASTO-F19S4G5
4 членов
Автор 6 руководств
Один комментарий
where can I buy fx505dy back cover replacement because mine has broken grills and stripped screw
Jakkinen Daniel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 23
За последние 30 дней: 164
За всё время: 4,943
