Введение
This guide will teach you how to remove the motherboard out of your Asus Transformer Book T100TAF.
Выберете то, что вам нужно
Detach the screen from the keyboard using the silver button and pulling the screen in the upwards direction.
Pry the plastic backing off of the tablet using the plastic spudger, releasing all interior clips.
Unscrew all the silver screws from the motherboard
3.0 mm (3) silver phillips head
Unscrew all the black screws from the motherboard with a PH00 screwdriver
4.5 mm (4) black phillips head
4.5 mm (2) black phillips head
Detach the battery cable by steadily pulling it away from the motherboard with angled tweezers.
Gently pry the orange ribbon cable that is near the battery cable upwards with tweezers.
Remove the black strip along the top edge, releasing the two sets of connections.
Use tweezers to detach the black and red twisted pair cable from its connection to the motherboard.
With tweezers, gently flip the white clip up that is holding the white ribbon cable down. Pull the base of the white ribbon cable away from the motherboard with tweezers.
Disconnect the bottom orange ribbon cable with tweezers by pulling it away from the edge of the device.
4 участников успешно повторили данное руководство.
