Выберете то, что вам нужно
Insert a small flat head screwdriver into the 2 docking station guide ports on the bottom of the tablet.
Unlock screen casing tabs
Push tab with screwdriver to the right until it clicks
You should see a small arrow in the bottom of the port
Unlock the tabs in both docking station guide ports.
Use spudger to push upward on the small plastic tabs on top of the docking station guide ports.
Insert the flat side of another spudger to start freeing the bottom of the screen from the case.
Use your spudger to open the four plastic tabs located on either side of the tablet.
Remove the screen from the body
Use your spudger to release the two digitizer ribbon cables from the mainboard.
Located on the left side of the tablet between the micro-HDMI and the microSD slot.
Use your spudger to release the LCD cable from the back of the LCD.
Set aside for later dissection.
To remove the front facing camera (right):
Use your spudger to unlock the ribbon cable
Slide the camera out
To remove the rear facing camera (top):
Apply light lifting pressure to unplug it from it's socket
Remove the backup battery on the right side:
Unplug the cable from the motherboard with your spudger
Remove the motherboard, daughterboard, and dock connector
Unscrew 14 points
Unplug the speaker from the motherboard before removing it
Reveal the battery connector:
Flip the motherboard from the top edge of the tablet down (towards the battery).
Unplug with light pressure from your spudger.
Disconnect the motherboard from the daughterboard:
Unlock the ribbon cable on the back side of the daughterboard
Remove the battery:
Remove screws (eight)
Use your spudger underneath the battery between the 2 cells to work it free
Remove the speaker:
Use your spudger underneath, and work it free
Remove the bottom screen locking mechanism:
Lift pieces out
Now that we're left with a boring empty shell, let's return to the LCD assembly that we set aside in Step 5.
Remove the 4 screws. Then work your spudger underneath the edges of the LCD to separate it from the Gorilla Glass front. It has a light adhesive around all edges.
With the LCD free, you should now be able to lay it out in a big pile of parts and the teardown is complete. Now let's see what's under all those heatsinks and tape.
The front side of the motherboard is where all the action is.
Tegra 3 quad core processor T33-P-A3
2x Elpida memory J4216EBBG-GNL-F
Realtek? ALCS631
Hynix H26M64002BNR e-NAND
Close-ups.
That's all I've got. I apologize for any blurry pics as all I had on hand was my cell phone ( <3 Samsung Galaxy Note.) I hope your teardowns are far less destructive than mine was. Good Luck.
...and yes, it still works after reassembly. Thanks for asking.
33 Комментарии к руководству
Does anyone know what the internal on/off switch does on the motherboard? Right next to the battery connector. How can you see that in a tear down and not mention it?
It is a master on/off switch. When the switch is flipped to the off position, the tablet will not operate. You can see the switch labels on the second picture of Step 13.
Ya its for when your doing work inside the tablet your supposed to flick that off so you dont accidentally short anything. Like the on/off switch on your power supply on the back of your desktop
Thanks for this teardown! Could the "mushy" power / volume buttons be due to poor placement of the buttons / board? Could slight nudging of the board in one direction or the other help the "mushy" buttons?
Hi there, thank you very much for this teardown. I wanted to inquire if you were able to find out anything about the gyroscopes/accelerometers/GPS and other sensors during this. I'm doing a project and this would be very helpful information.
