Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Make sure the power is off.
Insert the plastic opening tool into a crack on side of the tablet.
Carefully pull the tool upwards to and pry open the Transformer pad.
Slide the tool in the gap along all four sides, continually pulling the tool upwards.
Remove the back cover once it is loose and set it aside.
Rotate the tablet so it matches the picture.
Carefully unplug the battery cable from the motherboard by grabbing the wires close to the black piece and pulling it out of the housing.
Carefully pry the battery out of the tablet with the opening tool.
Remove two screws from each speaker with the +J000 screwdriver.
Remove the yellow tape and unplug the wire that attaches the speakers to the soundboard.
Use the +J000 screwdriver to remove the screw pictured. Then, remove the plastic cover that is labeled "M2".
Note: You will break the seal sticker on the screw.
Remove the black tape from the ribbon cable and separate the cable from the soundboard.
Remove the screws from the soundboard with the +J000 screwdriver.
Remove the black tape from the motherboard. Unplug the ribbon cable from the volume and power buttons.
Remove the three screws from the motherboard with the +J000 screwdriver.
Unhook the camera's ribbon cable from the underside of the motherboard and then remove the motherboard.
Remove the two keyboard connector screws with the +J000 screwdriver.
Remove the two charging port screws with the +J000 screwdriver.
Remove the charging port chip and the keyboard connector chip.
Remove all eight screws from the metal frame with the +J000 screwdriver.
Carefully unpeel the metallic tape from the left side of the frame.
Carefully remove the frame and avoid getting it caught in the wires.
Use the plastic opening tool to pry the display screen from the front panel.
For better results, use opening picks and glide them around the screen tape. Note: you may need to replace the tape.
9 участников успешно повторили данное руководство.
2 Комментариев
I was wondering if you could tell me which ribbon cable connects the screen, and in particular the touch input to the main board. I would guess that it is the one labeled 14010-00190900.
I am having the problem with intermittent touch input failure, and since my device is not on warranty, I thought I might try replacing the ribbon cable.
