Введение
Use this guide to replace the front-facing camera board on your Asus Transformer T100.
Запчасти
Никакие детали не требуются.
  1. Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet. Remove the tablet by lifting up.
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Insert the opening tool into the seam of the tablet casing and gently pry upwards. With a little force, you will feel the clips release.
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Remove the rear casing. Remove the rear casing.
    • Remove the rear casing.
  6. The camera board is located in the red square in this image.
    • The camera board is located in the red square in this image.
  7. Remove the two screws on the camera board using a Phillips #1 Screwdriver. Remove the two screws on the camera board using a Phillips #1 Screwdriver.
    • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
  8. Lift up the power button cable retention clip on the motherboard and pull the cable out. Lift up the power button cable retention clip on the motherboard and pull the cable out. Lift up the power button cable retention clip on the motherboard and pull the cable out.
    • Lift up the power button cable retention clip on the motherboard and pull the cable out.
  9. On the camera connection apparatus, locate the silver tape that connects to the tablet. Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • On the camera connection apparatus, locate the silver tape that connects to the tablet.
    • Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
  10. Gently pull the Orange ribbon cable  out of the connection port. This port has no clip. The orange apparatus should slide out with a small tug. This port has no clip. The orange apparatus should slide out with a small tug.
    • Gently pull the Orange ribbon cable out of the connection port.
    • This port has no clip. The orange apparatus should slide out with a small tug.
Заключение
2 участников успешно повторили данное руководство.
Taylor Pantiga
Участник с: 14.04.2014
1 313 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 13-31, Maness Spring 2014 Member of Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 членов
Автор 6 руководств
Один комментарий
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - Ответить
Просмотр статистики:
За 24 часа: 2
За 7 дней: 6
За 30 дней: 26
За всё время: 2,954
