Введение
Replace the hard drive in your Asus U47VC in order to get more memory space for your laptop.
Выберете то, что вам нужно
Remove the hard drive cover.
Unscrew one 8mm Phillips #00 screw.
Using the black spudger, insert its flat end under the hard drive's covering, working around to pry it off.
Remove the hard drive.
Unscrew the four 3mm Phillips #00 screws.
Pull the hard drive's black tab away from the laptop to free it.
Почти готово!
Заключение
