Введение
This guide will take you through the process of replacing the optical drive in an Asus U56E-BBL6 laptop. You will need the correct replacement optical drive for your laptop to complete the installation.
Выберете то, что вам нужно
Locate the battery locking tabs on the upper right and left corner.
Press the tabs in towards each other.
Use a plastic opening tool around the entire edge.
Separate the case from the keyboard.
Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
Using a plastic opening tool, separate the optical drive from the laptop frame.
