Введение
In this guide, you will learn how to replace the touchscreen display on the Asus V500CA-DB51T. This guide was made to help with replacing a broken or defective touchscreen display, and is a moderately challenging repair.
Выберете то, что вам нужно
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
Remove the tri-point screws that secure the battery to the casing.
All screws securing the battery in place are .5 cm tri-point screws.
Locate the section of the device that houses the WiFi Card.
This should be a white, square-shaped object located just above the left end of the battery.
Slowly lift up on the main case of the laptop.
Gently pull the laptop from the screen when it is perpendicular with the screen.
Еще один человек закончил это руководство.
