Введение
In this guide, you will learn how to replace the speakers in the Asus V500CA-DB51T. This guide was made to help with replacing broken or defective speakers, and is a moderately challenging repair.
Выберете то, что вам нужно
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
Remove the tri-point screws that secure the battery to the casing.
All screws securing the battery in place are .5 cm tri-point screws.
Remove the following screws securing the battery connector board to the logic board:
The red screws are size 2.3 cm T6 Torx
The orange screws are size 2.4 cm T6 Torx
Using the tweezers gently remove the ribbon cable.
Also using the tweezers pry off the metallic tape on both sides of the mouse pad.
Remove the mouse pad from the main assembly.
Remove the ribbon cable for the LED lights.
Remove the speaker wire cable from the main board.
Slowly pull the speaker wire from the assembly.
Gently pry the left speaker from the assembly.
Then pry the right speaker from the assembly.
