Введение
If you find that you need to replace the battery on the Asus VivoBook E203MA-TBCL432B, this guide will help you access it.
This replacement requires only a standard Phillips #0 screwdriver and a plastic opening tool. The screwdriver is used to remove the screws on the bottom panel of the laptop and the screws connecting the battery to the laptop. This is a simple replacement and should not require any additional knowledge or information.
Выберете то, что вам нужно
Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
Remove the two 7 mm Phillips #0 screws.
Insert the iFixit opening tool in between the back panel and the rest of the laptop.
With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
Now that the back panel is removed you can clearly see the battery and all of its connectors.
Begin by removing the silver ribbon cable along the back of the battery.
To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
Disconnect the ribbon cable from the left side in the same way.
Remove the red and black wire along the bottom of the battery.
This does not need to be disconnected, only removed from the clamps along the bottom of the battery.
Using the Phillips #0 screwdriver, remove the two 3 mm screws located at the top and left side of the battery.
Gently lift the battery being mindful of the one cable still connected to the motherboard.
With the battery lifted, pull the remaining connector going to the motherboard up, it should come out with little force.
8 участников успешно повторили данное руководство.
