Введение
Battery life of any device will eventually shorten over a period of time. This guide will show you how to replace a used battery with a brand new one.
Выберете то, что вам нужно
Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
Use a plastic opening tool to pry the back panel off.
Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
5 участников успешно повторили данное руководство.
4 Комментариев
Hey I need help with getting the battery out with Asus Vivo-Book E406SA
Need help getting the battery out of my E406sa
could you show me how to unplug the connector without breaking it?
