Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will show you how to remove the fan for replacement or cleaning.
  1. Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center). Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Use a plastic opening tool to pry the back panel off.
    • Use a plastic opening tool to pry the back panel off.
  3. Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place. Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Remove the ribbon cable with a pair of tweezers. Remove the ribbon cable with a pair of tweezers.
    • Remove the ribbon cable with a pair of tweezers.
  6. Lift and remove the battery.
    • Lift and remove the battery.
  7. Gently peel off the tape from the fan.
    • Gently peel off the tape from the fan.
  8. Remove five 5mm screws using a Phillips 0 screwdriver. Remove the two 2mm screws with a Phillips 000 screwdriver.
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  9. Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  10. Grab the sides of the fan assembly and remove it by lifting upwards. Grab the sides of the fan assembly and remove it by lifting upwards.
    • Grab the sides of the fan assembly and remove it by lifting upwards.
Заключение
2 участников успешно повторили данное руководство.
Bryann Tan
Участник с: 25.09.2016
784 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 16-2, Eyestone Fall 2016 Участник USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 441
