Введение
This guide will show you how to replace the wireless adapter chip in your VivoBook.
Выберете то, что вам нужно
Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
Почти готово!
Заключение
