Введение
Bad keys are a result of lint or dirt underneath the keys or over use that has caused it to become unresponsive. To fix this problem, simply follow the guide below.
Place fingernail underneath the key you wish to remove.
Gently pry the key off.
Now make sure the mechanism is clean. If needed you can clean it with compressed air.
5 участников успешно повторили данное руководство.
