Введение
This guide will show you how to remove and replace the motherboard if you are experiencing performance issues.
Выберете то, что вам нужно
Turn off the computer and unplug the charge cable.
Turn the computer upside down.
Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
The battery is attached by a set of wires.
Use your finger to disconnect the set of wires. It should come off very easily.
Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
Remove the one 4.9mm screw that holds the wireless card in place with a Phillips #00 screwdriver.
Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
Next, carefully lift the LAN bracket out of the slot.
Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
Locate and unplug the power bus from the motherboard.
The motherboard can now be replaced.
