Введение
The Asus Vivobook S200E-RHI3T73 is a Windows 8 laptop, equipped with a 11.60-inch display that has a resolution of 1366x768 pixels. It also contains a RAM with 4GB and 500 GB of HDD storage. This form will guide you in the replacement of the DC Jack in your Asus VivoBook S200E-RHI3T73. Follow the instructions in order for the best results.
Выберете то, что вам нужно
Remove the five 8.0 mm screws using the Phillips #0 screwdriver.
Remove the four 5.0 mm screws using the Phillips #0 screwdriver.
Carefully remove the back of the laptop and set it aside.
Use a Phillips #0 screwdriver to remove the twelve 5.0 mm screws securing the battery.
Use a spudger to gently lift the connector tab between the battery and the circuit board.
Gently remove the battery from the laptop.
Use a Phillips #0 screwdriver to remove seven screws from the right half of the motherboard.
Use a Phillips #0 screwdriver to remove the 5.0 mm screws from the fan and disconnect the fan port.
Use the screwdriver to remove remaining screws from the right side of the motherboard.
Remove the four screws from the Ethernet port and disconnect the Ethernet port.
Pull the motherboard to the left and upward to remove it from the laptop.
Locate the DC Jack on the motherboard.
Use a soldering iron to disconnect the DC Jack from the motherboard.
This guide gives step by step instructions for replacing the DC Jack on an Asus Vivobook S200E-RHI3T73.
2 участников успешно повторили данное руководство.
