Введение
Replace your unresponsive screen to return display to your VivoBook.
Выберете то, что вам нужно
With the screen closed, place your laptop upside-down with the front facing you.
Remove the five black 80mm Phillips #0 screws.
Remove the four black 50mm Phillips #0 screws.
Use a metal spudger to pry the bottom panel open.
Lift the back panel to expose the inside of the laptop.
Using a Phillips #0 screwdriver, remove the four 2mm silver screws located at each of the four corners of the screen.
Gently lift the screen up and over.
Use tweezers to remove the EX2 LVDS connector cable that connects the screen and the laptop.
Remove the screen.
4 участников успешно повторили данное руководство.
