Введение
In the case that your Laptop’s Touchpad stops working, you may need to replace it. This guide shows you how to replace the Touchpad in just a few simple steps.
Выберете то, что вам нужно
In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
There are five 80mm screws.
There are four 50mm screws.
Pull the back lid off of the laptop using your fingers.
Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
Disconnect the LED ribbon wires using a spudger to lift the clamp.
Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
Using a spudger, gently lift the silver ground strips off of the touch pad.
Pull the touch pad up and towards the battery to remove it from the laptop.
