Введение
If your VivoBook continues to fail to connect to the internet after troubleshooting the internet settings, you may need to replace the WiFi Chip.
Выберете то, что вам нужно
With the screen closed, place your laptop upside-down with the front facing you.
Remove the five black 80mm Phillips #0 screws.
Remove the four black 50mm Phillips #0 screws.
Use a metal spudger to pry the bottom panel open.
Lift the back panel to expose the inside of the laptop.
Use precision tweezers to pry the black wire with a gold plug off the main gold plug on the module.
