Введение
The motherboard is the brain of the computer. It controls everything from image generation to file access and everything in-between. This component can get damaged due to liquid exposure, drops from tall heights, and insect infestations. Take care to make sure the motherboard is disconnected from power before starting.
Выберете то, что вам нужно
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
Remove the single 3mm screw from the sound chip.
Unplug the sound chip.
Remove the sound chip.
Еще один человек закончил это руководство.
