Введение
Through the course of normal use, it is possible that the in-built speakers in the Asus Vivobook X540SA will become damaged or stop functioning. In this guide, the user will find step-by-step instructions for opening up the device, accessing the speakers, and removing them.
Выберете то, что вам нужно
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
Remove the two battery screws (15.6 mm)
Two top corner screws (12.5 mm)
Six case screws (9.7mm)
Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
The Disk Drive is located within the upper right hand corner of the laptop.
Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
The Hard Drive is located in the bottom right hand corner. It should be the device covered in black foam.
Using the Phillips #0 screwdriver, unscrew the four (5.7cm) screws around the hard drive.
Using the blue plastic opening tool in the iFixit tool kit, slide the hard drive to the right to remove it from the case.
Gently use the metal spudger to loosen speaker from adhesive, by first loosening the far right side and working your way to the left.
Еще один человек закончил это руководство.
