Введение
If your screen is cracked, broken, scratched, or otherwise in need of replacing, this guide will show you how to disassemble your computer, and replace the screen with a new one.
Выберете то, что вам нужно
Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
Now that the screen is completely detached, lay the back panel flat on a smooth surface.
Lift the screen to view the inside of the tablet.
Before disconnecting the display cables, refer to the image to turn off the switch labeled DIP; this switch is used to de-energize the system.
After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
Congratulations! You have now successfully removed the screen from your device. To attach your new screen and reassemble your device follow these instructions in reverse order.
5 человек успешно провели ремонт по этому руководству.
