Введение
This guide will show you how to remove the back panel and remove/replace the battery for the Asus VivoTab Smart tablet.
Once you are done, calibrate your newly installed battery by draining it below 10% and then charging it uninterrupted to 100%.
Выберете то, что вам нужно
Place the device face down on a flat surface.
Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
Remove the tape covering the areas marked by the black arrows
Remove two 3.7 mm Phillips #00 screws
Remove eleven 2.7 mm Phillips #00 screws
Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
Lift up on the speaker with your fingers to remove it.
Use tweezers to separate the battery tray from the device
Lift the battery tray from the device using your hands.
Detach the battery from the tray by pulling the battery up from the tray with your hands.
3 участников успешно повторили данное руководство.
2 Комментариев
Hi
So where is the next step ?!
Hi
Please answer to me. This is so
