Введение
The tablet comes with two cameras. Replacing the back camera will be the sole focus of this guide.
Выберете то, что вам нужно
Place the device face down on a flat surface.
Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
