Введение
Follow this guide if you need to replace the motherboard of your Asus VivoTab Smart tablet.
Выберете то, что вам нужно
Place the device face down on a flat surface.
Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
Еще один человек закончил это руководство.
