Введение
The Disc Drive is an essential part of the laptop which is needed to read or write data onto a CD. This guide will show you how to remove and replace the Disc Drive drive of the Asus Vivobook Max X541SA-PD0703X.
Выберете то, что вам нужно
Flip the laptop upside down so that the back of the laptop faces you.
Remove the following ten Phillips #0 screws from the bottom of the laptop:
Six 13mm screws.
Four 11mm screws.
Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
Pull the ribbon cables out of their sockets.
Remove the hard drive by pulling it towards the right, and removing it from the laptop case
Remove the disc drive by sliding it towards the right and removing it from the laptop case
