Введение
This guide will show you how to replace the Motherboard of your Asus Vivobook Max X541SA-PD0703X. In order to replace the Motherboard, you will have to remove the hard drive, wifi card, and CD insert.
  1. Flip the laptop upside down so that the back of the laptop faces you.
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
      • Six 13mm screws.
      • Four 11mm screws.
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
    • Remove the three 6mm Phillips #0 screws from the motherboard.
    • Pull the Wi-Fi card out of the motherboard.
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
    • Remove the plastic covering off of the motherboard.
    • Remove the five 6mm Phillips #0 screws from the motherboard.
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
    • Pull the motherboard to the right and lift up.
Заключение
Hetvi Mehta
Участник с: 22.02.2018
651 Репутация
Автор 5 руководств
Команда
USF Tampa, Team S1-G4, Cagle Spring 2018 Member of USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 8
За 30 дней: 47
За всё время: 465
