Введение
This guide will show you how to replace the Motherboard of your Asus Vivobook Max X541SA-PD0703X. In order to replace the Motherboard, you will have to remove the hard drive, wifi card, and CD insert.
Выберете то, что вам нужно
Flip the laptop upside down so that the back of the laptop faces you.
Remove the following ten Phillips #0 screws from the bottom of the laptop:
Six 13mm screws.
Four 11mm screws.
Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
Pull the ribbon cables out of their sockets.
Remove the hard drive by pulling it towards the right, and removing it from the laptop case
Remove the disc drive by sliding it towards the right and removing it from the laptop case
Remove the three 6mm Phillips #0 screws from the fan shroud.
Remove the shroud from the motherboard.
There is a wire attached to the screen display.
Peel the sticker and disconnect it from the motherboard.
Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
2 участников успешно повторили данное руководство.
