Введение
If your track pad has become unresponsive, it may be time to replace it. This guide will show you how to replace your track pad.
  1. Make sure the computer is turned off.
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Remove the four 5mm Phillips #1 screws from the top of the laptop. Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Lift off the cover and remove the back cover from the device.
    • Lift off the cover and remove the back cover from the device.
  5. Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place. Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
    • Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
  6. Unplug the battery connector from the mother board. Unplug the battery connector from the mother board.
    • Unplug the battery connector from the mother board.
  7. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  8. Gently remove the battery from the slot. Gently remove the battery from the slot.
    • Gently remove the battery from the slot.
  9. Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place. Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place. Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
    • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  10. Remove the wire connecting the fan to the motherboard. Remove the wire connecting the fan to the motherboard.
    • Remove the wire connecting the fan to the motherboard.
  11. Gently remove the fan and heat sink from the motherboard. On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
    • Gently remove the fan and heat sink from the motherboard.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
  12. Remove the four 4.0 mm Phillips #1 screws shown.
    • Remove the four 4.0 mm Phillips #1 screws shown.
    • Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the three 3.0 mm Phillips #1 screws shown.
  13. Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it. Pull the hinge the rest of the way up.
    • Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
    • Pull the hinge the rest of the way up.
  14. Disconnect the motherboard from the two connectors shown.
    • Disconnect the motherboard from the two connectors shown.
  15. Disconnect the motherboard from the connector shown.
    • Disconnect the motherboard from the connector shown.
  16. Pull the motherboard loose.
    • Pull the motherboard loose.
  17. Disconnect the motherboard from the connector shown and it is now removed from your device.
    • Disconnect the motherboard from the connector shown and it is now removed from your device.
  18. Remove the four 2.0 mm Phillips #1 screws holding the track pad in place.
    • Remove the four 2.0 mm Phillips #1 screws holding the track pad in place.
  19. Remove the tape connecting the track pad to the frame of the device. The track pad is now completely disconnected from the device.
    • Remove the tape connecting the track pad to the frame of the device. The track pad is now completely disconnected from the device.
Заключение
Samuel Foster
Участник с: 06.11.2018
157 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 Member of UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G3
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 1
За всё время: 67
