Введение
If your fan is either broken or not running correctly, use this guide to replace it. This repair can be completed by one person using a PH1 Philips Head Screwdriver. Keep in mind that the Asus Vivobook S500CA uses a specific model fan, which must be acquired before beginning this replacement.
Выберете то, что вам нужно
Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
Remove 2 (.5 cm) Phillips Head screws found around the fan and 4 (.3 cm) Phillips Head screws found around the heat sink connector.
Unhook the electronic connection located above the fan by pulling the white connector straight out of the brown socket.
Еще один человек закончил это руководство.
