Введение
If your hinges are broken or stuck, use this guide to replace them. This repair can be completed by one person using a PH1 Philips Head Screwdriver. Keep in mind that the Asus Vivobook S500CA uses a specific hinge mount points, these parts must be acquired before beginning this replacement.
Выберете то, что вам нужно
Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
Remove 3 (.5 cm) phillips screws around the edge of the hinge. Repeat for other side.
Disconnect the black and white wires from the “Aux” (white) and “Main” (black) ports
Open the device to access the plastic casing over the hinges.
Remove the casing by lifting firmly. This step can be difficult.
Remove 4 (.5 cm) screws from the hinge. Remove the hinge and follow steps in reverse order to reassemble and complete repair.
Один комментарий
Hi.
The Asus X550C set screen (screen + flat cable) is compatible with Asus S500CA notebook? Anybody know response for me? Tks
