Введение
Remove the disc drive on your Asus W2W-A1 so that you may replace it with a new disc drive or a stick a hard drive in its place.
Запчасти
Никакие детали не требуются.
  1. Use a Phillips head screwdriver to remove the one 3mm screw labeled D on the back of the laptop.
    • Use a Phillips head screwdriver to remove the one 3mm screw labeled D on the back of the laptop.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides. With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
    • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
Заключение
Emily Mullins
Участник с: 14.04.2014
201 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 13-29, Maness Spring 2014 Member of Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 188
