Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Replace a broken hard drive or upgrade your hard drive to increase your storage space.
Запчасти
Детали не указаны.
  1. Before disassembly, make sure the laptop is powered off and the battery is disconnected.
    • Before disassembly, make sure the laptop is powered off and the battery is disconnected.
    • Remove the two screws (size?) on the lower panel at the bottom of the laptop (identify tool to use).
  2. Grab the panel and lift upwards while pulling towards yourself.
    • Grab the panel and lift upwards while pulling towards yourself.
  3. Remove the 3 4 mm Phillips upper screws holding the hard drive down.
    • Remove the 3 4 mm Phillips upper screws holding the hard drive down.
  4. Pull the hard drive towards yourself to disconnect it from the laptop.
    • Pull the hard drive towards yourself to disconnect it from the laptop.
  5. Lift the hard drive upwards to remove it from the laptop.
    • Lift the hard drive upwards to remove it from the laptop.
Заключение
Nolan Schock
Участник с: 14.04.2014
501 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 13-29, Maness Spring 2014 Участник Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 193
