Выберете то, что вам нужно
Using the Phillips 1 screwdriver, remove the laptop's back panel.
Pry open the Keyboard/Touch pad.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Detach keyboard and touch screen cables
These are the cable that are holding the keyboard and touch screen together
Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
Slide out the hard drive
Remove motherboard screws
These would be located on the green panel which is the motherboard
