Выберете то, что вам нужно
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Take two rubber caps off the back side of the laptop.
Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Remove the following four screws:
Four 4 mm Phillips #0 using a phillips screwdriver.
3 участников успешно повторили данное руководство.
2 Комментариев
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
