Выберете то, что вам нужно
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Look at comments in the previous step. There are 2 more screws.
Remove the following four screws:
Four 4 mm Phillips #0 using a phillips screwdriver.
Slide out the hard drive
Slide the drive to the right, away from the sata connectors at the left.
3 участников успешно повторили данное руководство.
2 Комментариев
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
There are also two other screws under the rubber feet above the battery.
digg1024 - Ответить
I agree. Two another 14 mm screws under the rubber feet.
shao.onii - Ответить
