Введение
Use this guide to replace the trackpad on your Asus X200MA.
Инструменты
Запчасти
Никакие детали не требуются.
Remove the following six screws:
Six 4 mm Phillips #0 using a phillips scredriver
Remove the following one screw:
One 14 mm Phillips #0 using a phillips screwdriver
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
Remove the following eight screws:
Eight 3 mm screws using Phillips #0 screwdriver.
Remove the following two screws after lifting metal plate off:
Two 2 mmm screws using a Phillips #0 screwdriver.
