Введение
If your AsusX202E does not turn on or looses power quickly use this guide to replace the battery.
Выберете то, что вам нужно
Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open.
Once the back is off the device, unscrew the 7 1.2mm phillips head screws that hold the battery in place using a small phillips head screw driver
Once the screws holding the battery are out, use the plastic opening tool to disconnect the battery cable ribbon from the motherboard
To reassemble your device, follow these steps in reverse order.
Еще один человек закончил это руководство.
