Введение
This device will show you how to replace a faulty ethernet port with a new working one.
Выберете то, что вам нужно
Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open with your fingers
Remove the 4 1.2mm phillips head screws with a small phillips head screw driver that held the Ethernet port in place.
Lift and remove the Ethernet port
