Введение
The ASUS laptop is actually quite easy to open up and work on, there are however 2 flat ribbon cables which you should know about.
Выберете то, что вам нужно
Turn laptop over on flat, stable surface.
Remove 8 Phillips Screws
Slide battery lock to unlocked position on left side, then hold it in on the right side while sliding the battery out.
Turn over laptop
Open lid as far as it will go
Insert opening pick as shown
Follow entirely around the laptop
On the underside of the keyboard are 2 flat cables connected to the surface.
You can use a opening pick to pop these out of their respective slots on the main board.
Using an opening pick you can now undo the connector for over the hard drive.
There is adhesive holding the flat cable to the hard drive.
Slide something under the flat cable to gently remove it.
Slide flat cable out of socket.
Using a finger you can now slide the hard drive out
6 участников успешно повторили данное руководство.
