Введение
If you find your computer running slow, it may be time to upgrade your RAM. Having more RAM will give your computer more zip for activities such as browsing the internet. It is important to turn off and unplug your laptop before starting this guide. The screws you remove in this repair are small, so be sure to have a magnetic mat handy!
Выберете то, что вам нужно
Turn laptop over and remove battery by sliding latches, and pulling up and out.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Using a Phillips Head #1 screwdriver, unscrew ten screws from the back of the laptop.
Eight screws are 3mm.
Two screws are 4mm. Place screws on magnetic mat.
Pry open computer using plastic opening tool. You will be separating the keyboard from the back of the computer.
There are two ribbon cables connecting the keyboard to the motherboard.
The larger cable is a ZIF (Zero Insertion Force) cable. As the name implies, you do not need to use force to insert or disconnect this cable. Disconnect this ribbon cable by unlocking the holding latch and pulling out gently.
The smaller ribbon cable requires nothing more than pulling it out gently.
Disconnect the red, black, and white wires connecting the speakers by pulling gently.
Using a Phillips Head #1 screwdriver, unscrew the seven 3 mm screws holding the motherboard in place. These are marked with white arrows on the motherboard (not shown in image).
Remove the two 3 mm screws holding the fan in place
Remove the two 3mm screws holding the USB and charging port on the frame.
Disconnect the USB and charging port from the motherboard. There will be a ribbon cable as well as some wires to disconnect. Use a spudger if necessary.
Use spudger to lift motherboard, frame, and fan.
Once lifted gently pull the motherboard to the left to remove the ports on the right side from the frame.
Set the frame aside and turn over the motherboard.
Release tension brackets on both sides of RAM and slide it up and out at a 45 degree angle.
4 участников успешно повторили данное руководство.
