Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will explain how to locate and replace the fan inside of the Asus X501A-RH31 laptop. This replacement guide will fix the cooling aspect of the computer.
  1. Turn the laptop over so that the back is facing upwards.
    • Turn the laptop over so that the back is facing upwards.
  2. To unlock the left tab, make sure the tab on the left has red showing.
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. To unlock the right tab, push the right slider to the left with one hand. Push the battery out with the other hand.
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop.
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop.
    • The nine screws are 7 mm long, 4.5 mm in diameter.
  5. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  6. Turn the laptop over and open the top so  the keyboard is facing you.
    • Turn the laptop over and open the top so the keyboard is facing you.
  7. Pry off the keyboard cover on the edge using the plastic opening tool. Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  8. Slowly lift the keyboard upward, but do not remove completely.
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  9. Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  10. Unscrew the three screws using the Phillips #00 screwdriver.
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  11. Unscrew the three screws on the left hand side of the big motherboard.
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  12. Remove the connector cable attached to the bottom of the motherboard. Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable. Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
Заключение
Christopher
Участник с: 19.10.2017
332 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 Участник UMass Dartmouth, Team S3-G3, Bailey Fall 2017
UMASSD-BAILEY-F17S3G3
3 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 232
